H9000 : Emote Plugin not connecting after 1.0.0.21 update
Home Forums Products Rackmount H9000 : Emote Plugin not connecting after 1.0.0.21 update
Viewing 3 reply threads
    • #114809
      zazula
        Hi –
        Is anyone else having trouble connecting to the H9000 from the Emote plugin after the 1.0.0.21 update?
        Thanks,
        Ralph
      • #149591
        floresp640
          zazula wrote:
          Hi –
          Thanks,
          Ralph
          Hi Ralph,
          I’m sorry you are having issues in regards to connecting to Emote. What version of the H9000 software are you currently running? If you’re not running the latest software version (1.0.0.25) you might have some trouble connecting to the latest version of Emote. Please make sure that your software is up to date.
          If you’re still having trouble despite having the correct software, we would need to take a closer look at the issue.
          Thanks Ralph! Hope this helped!
          Pat
        • #149592
          zazula
            I’m running 1.0.0[25] on the unit.
          • #149594
            floresp640
              How are you connecting to the network on your H9000? Is Emote sporadically disconnecting?
              • #149595
                zazula
                  floresp640 wrote:
                  Hi, How are you connecting to the network on your H9000? Is Emote sporadically disconnecting?
                  Computer and H9000 plugged into a switch.  DHCP over Ethernet.  All was working well with the previous software release (plugin and standalone).  Now, only the standalone Emote works.
