Home › Forums › Products › Rackmount › H9000 Feature request: digital outs selectable via highlighted FX chains
March 3, 2020 at 3:15 pm #115808
This would be smooth. Would like to switch from my ADAT to AES either in a tab in the effects chain (using emote) or a setting like “digital out follows fx chain” and have that info stored in the chain, so when you highlight it, the H9000 follows that setting automatically.
March 12, 2020 at 1:38 pm #154295
Yeah this would be super useful. Just switched over to AES from ADAT and it’s a massive pain to re-route for every session. One other request for the routing tab is an option to have the channel you’re routing from de-select after making a connection to speed up connecting multiple channels in a row (or a Cascade option to connect a selected amount sequentially like on a Digico).
March 18, 2020 at 6:23 pm #154345rskaudio wrote:
Yeah this would be super useful. Just switched over to AES from ADAT and it's a massive pain to re-route for every session. One other request for the routing tab is an option to have the channel you're routing from de-select after making a connection to speed up connecting multiple channels in a row (or a Cascade option to connect a selected amount sequentially like on a Digico).
Hi! One pro tip that could make connections smoother is to 'Drag and Drop' your IO's. You can do this with your algorithm IO's and your hardware IO's. If you click and hold on an IO number (ex. Analog 1) and drag it into the input of an algorithm slot (ex. Input 1 of Blackhole) you will see that the connections will automatically un-highlight when the connection is made. Alternatively, clicking the ESC key will remove the highlight from any connections.
