#6417 Send/Return
Home Forums Products Rackmount #6417 Send/Return
Viewing 0 reply threads
    • #194927
      apossibleworld
        Can anyone explain how to use the Send/Return algorithm #6417 of the H9000?  The guidebook says:
        Stereo send and return preset. input #1 and 2 to the dsp are the sends, input #3 and 4 to the dsp are the returns. Use this as a tempate to set up send/return functions inside a preset to and from the second engine. Quad in, quad out.
        I was hoping I might use this to create some internal feedback networks, is that possible?  If not, what are the other uses for this?  If someone could send a screenshot of how to route this properly that would be very helpful!  I’ve been experimenting but not getting it to work yet.  If inputs 3/4 are the returns, you don’t touch the outputs at all?  My brain is confused haha.  I see this block is also present in H8000 so maybe someone here has tried this before.
