H9Max and Boss ES5
Home › Forums › Products › Stompboxes › H9Max and Boss ES5
Viewing 3 reply threads
    • #116333
      turretboard
        Can I count on you with a idiot proof guide how to link my H9Max to Boss ES-5 switcher please? I’m also using external switch for tap tempo and I would like to know how to make it to do tap tempo via midi – other than general patch creation
        Thank you
      • #157065
          Alas, we do not have such a document. I fear some User Guide reading is required.
          We know little about Boss products, and a lot would depend on your setup and how you plan to use it.
          Hopefully someone out there has done the same thing and will chime in.
        • #157070
          bohan
            page 36 tells how you set the MIDI mappings for H9. You just assign a MIDI CC value to Tap Tempo and that's it. This can also be done more easily in H9 Control.
            https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/H9-UserGuide.pdf
            That's all I can help. You need to ask Boss about how you generate a MIDI CC from you external switch via ES-5, but I'm pretty sure this is doable.
          • #157072
            turretboard
              Thank you for all replying. I will start to sink in it today after work. Hopefully its not as scary as it seems.
