Help for a noob
Home Forums Products Stompboxes Help for a noob
    • #166418
      d070473
        Hi everyone,
        So I have 2 H9s and a HX Stomp. I think there is a more sophisticated way to connect them as I currently just have the guitar into the HX Stomp and then a connecting cable to an H9 linked by another connecting cable to the other H9.
        what should I be doing for maximum use?
        thanks in advance
      • #166447
          There is no right or wrong way of doing this. It is up to you and what you are trying to achieve with your equipment that will determine how you want to set everything up. If you are happy using the configuration you are using already, there is nothing wrong with that.
          One alternative would be to use one of the H9s with the send/return of the HX Stomp, and then place the other H9 either before or after the HX Stomp. You can consult the HX Stomp user guide for some more details about how to set that up: https://line6.com/data/6/0a020a418962611d636e7c51b/application/pdf/HX%20Stomp%203.0%20Owner’s%20Manual%20-%20Rev%20D%20-%20English%20.pdf
        • #166494
          d070473
            Thank you!!
