Help needed with PF; using footswitch for tap tempo
Home › Forums › Products › Stompboxes › Help needed with PF; using footswitch for tap tempo
Viewing 4 reply threads
    • #109325
      air621
        I'm having a hard time figuring this out. Maybe I can't even do it. What I want to do is use my non-latching footswitch (Boss FS-5U) as a tap tempo across the board on all my (or just a couple) banked presets. Can anyone help? Thanks!
      • #124045
        The footswitch inputs can only change the settings listed on page 47 of the PitchFactor manual, one of which is the same tap tempo as the right footswitch on the PitchFactor. If the tap tempo footswitch is not what you are looking for, could you explain more about what you are trying to do?
      • #124046
        air621
          Thanks for replying. The issue is that to use the tap tempo I have to exit out of the banks. I was hoping I could use the external footswitch to tap in a tempo without having to get out of the bank mode
        • #135037
          Yes, an external footswitch will always control what it is assigned to regardless of play/bank mode.
        • #135040
          air621
            Thanks. The other part of my question was hoping that someone could quickly walk me through how to do this
