How do I change a preset via iPhone in bypass mode
Home › Forums › Products › Stompboxes › How do I change a preset via iPhone in bypass mode
    • #113672
      Is it possible. Seems to always stay in active mode
    • #144241
      gkellum
        If a preset is saved bypassed and the H9 is bypassed, then it would load bypassed.  All of the factory presets though are saved as active, and if you're loading those, they will switch the H9 to active.
        If you're trying to use this in performance, I'd create a preset list with all of the presets you want to use and save them all bypassed.
      • #144273
        I’m trying to save the preset in the lists section via Bluetooth… But no luck. Always flips over to active
