How to bypass with pedal foots witch jack
Home › Forums › Products › Rackmount › How to bypass with pedal foots witch jack
    • #111914
      realrasslinfan
        I hope all is well with you as you read this.
        i cannot figure out how to use one of the pedal inputs on the back of the Eclipse to set it to bypass the unit.  I want to control this function with the Voodoo Labs GCX without putting the Eventide in a loop, but rather use the foot switch or even a midi cc command.
        all help appreciated
      • #126668
          See the section in the UM on External Controllers, p.45-47.
          P.47 shows you the BYPASS controller, p45/46 shows you how to set it up.
        • #126683
          realrasslinfan
            Thanks, worked perfectly!!!
