How to create pitch and pan modulation on input signal
Home › Forums › Products › Rackmount › How to create pitch and pan modulation on input signal
    • #112966
      I want to get pitch and pan modulation EFX on an stereo analog tape delay that I run through the parallel EFX loops of 2 amps.  I have an Eclipse and 2 H9s so I’m posting same question in both forums.  I suspect this is a “dumb” question that is easily addressed but I can’t figure it out.  I am running the repeats only (no dry signal) thru the parallel EFX loops.  I want to send them to the Eclipse 1st for pan and slight pitch modulation but I don’t want any further delays on the repeats.  Is there a way to input these repeats and get slight pitch and pan modulation w/o using a delay or obvious chorus/ flange effects?   The Tape EFX don’t have much modulation and no panning EFX
      Thx!
    • #141260
        You could try something like preset 160, "4 Detuners."
        • #141261
          nickrose wrote:
          You could try something like preset 160, “4 Detuners.”
          Thanks!  I’ll give it a try.  Can I simply modulate the cent value on a detuner, zero the delays and modulate pan?  Or, do I need a delay for it to work?  I was hoping for no additional delays on my repeats.
