Home › Forums › Products › Stompboxes › How to load pre-H9 control presets after updating TimeFactor firmware
February 25, 2017 at 11:25 pm #114028
axman53
ParticipantI’m about to finally upgrade my TF firmware to a version that works with H9 Control software. Is there a published procedure on how load my saved pre-H9 presents onto the TF once the firmware is upgraded? I’m assuming I will first backup the presents like I do now, so will that backup be usable once I upgrade to the H9 firmware version? Thanks.
February 28, 2017 at 10:17 pm #145832axman53 wrote:
I'm about to finally upgrade my TF firmware to a version that works with H9 Control software. Is there a published procedure on how load my saved pre-H9 presents onto the TF once the firmware is upgraded? I'm assuming I will first backup the presents like I do now, so will that backup be usable once I upgrade to the H9 firmware version? Thanks.
Sorry – you don't say how you backed up your presets, so it is not possible for us to say if it will be useable.
March 1, 2017 at 3:37 pm #145839
Factorlib has been replaced by H9Control, but it should still work.
Note that if your presets are very old, there may be compatibility issues, but I suggest you try it and see.
March 2, 2017 at 11:49 am #145851
axman53
Participantnickrose wrote:Note that if your presets are very old, there may be compatibility issues, but I suggest you try it and see.
Yes, and that is the question. What is the PROCEDURE for restoring a factorlib/syx backup using H9 Control? Thanks.
March 2, 2017 at 3:34 pm #145853
cudbear2018
Memberaxman53 wrote:Yes, and that is the question. What is the PROCEDURE for restoring a factorlib/syx backup using H9 Control? Thanks.
You can just drag and drop the syx file onto H9 Control and it will import it.
