Home › Forums › Products › Stompboxes › I can’t log in to H90 control
- This topic has 24 replies, 7 voices, and was last updated 3 months, 2 weeks ago by
Eventide Staff.
June 3, 2026 at 3:47 am #195584
I can log in to the website just fine, but it’s not working with H90 Control. I’m using the same account name (NOT the email adress) and password, of course. But I keep getting a login error and I’m stuck.
I have a MacBook Pro M3 Max and I’m currently using Sequoia 15.7.5.
I hope someone can help me soon.
June 3, 2026 at 5:17 am #195590
I also can’t log in on my iPad.
Another related question: how can I update my firmware if I don’t have access to H90 control?
June 3, 2026 at 5:30 am #195592
Same here. Can’t login on Win11 this evening (Australia). Was fine this morning.
Why is there no offline option? This is absolutely ridiculous given the price tag.
June 3, 2026 at 6:07 am #195596
Same here. Can log in in there website, but there I see I have no plugins or hardware registered anymore
June 3, 2026 at 6:08 am #195597
Same here, new H90, MacOS. I can login to eventideaudio.com but it won’t let me login to the H90 Control app on both my mac and my iPad. Also noticed that none of my existing hardware is showing on my account.
June 3, 2026 at 6:15 am #195598
my hardware is also missing from the website
it seemed like it was going to login for a few seconds just now but then kicked me out again
June 3, 2026 at 6:15 am #195599
dupl
June 3, 2026 at 8:49 am #195608
Same here
June 3, 2026 at 11:53 am #195614
Seems to be fixed now.
June 3, 2026 at 1:17 pm #195618
There was an issue with our server but it is now resolved. Please try logging in again.
Sorry for the inconvenience.
June 4, 2026 at 3:52 am #195632
Unfortunately, I’m still having the problem. I can log in to the website but not to H90 control. I’ve downloaded the editor again, but it hasn’t changed anything. It’s frustrating!
(and yes, of course I take my username) -
June 4, 2026 at 3:57 am #195633
Might be worth sending an email to support, they do respond quickly. I’ve got everything working fine here.
June 4, 2026 at 4:27 am #195634
I’ve already done that. I’m just writing it here again in the hope that my problem will be solved more quickly.
June 4, 2026 at 5:02 am #195635
Sorry to ask something obvious – is your username all lower case when logging into H90 Control? “sigitar” not “Sigitar” ?
June 4, 2026 at 5:04 am #195636
Valid question. But I only use lowercase letters.
June 4, 2026 at 5:16 am #195638
Can you see the H90 and any other hardware you’ve got registered on the website? What are you using to access H90 Control?
June 4, 2026 at 5:20 am #195639
I’ve returned to Eventide after years and haven’t registered anything yet. The H90 is new, and I’d like to register it via the control editor. As far as I know, there’s no other way, is there?
What is this ilok? Does it have anything to do with it? -
June 4, 2026 at 5:25 am #195640
Think you have to register it via H90 Control and then it shows up in your eventideaudio.com account under Hardware. I only got mine yesterday, long time Eventide user.
If you’re using an ipad, might be worth completely deleting the app and starting again with a fresh download? That will remove any data which might be causing a problem logging in.
June 4, 2026 at 5:28 am #195641
I use both an iPad and a MacBook. I deleted and reinstalled the app on both devices. Unfortunately, without success…
June 4, 2026 at 5:32 am #195642
Annoying isn’t it. Can’t think of anything else, sorry.
I’m sure one of the Eventide techs will get back to you quickly though and get you running, they’ve always been spot on when I’ve had problems.
June 4, 2026 at 5:33 am #195643
Absolutely. I hope to receive a reply soon. Thank you for your effort!
July 28, 2026 at 3:51 pm #196518
I can’t log in either. Have you find a solution?
July 29, 2026 at 8:50 am #196538
The original post was due to a server error we were having. There are currently no errors with our server and I was able to login to the app with no isses.
Can you please provide more information? What happens when you try to login?
You need to login with your Eventide username, not your email address.
July 30, 2026 at 2:08 pm #196580
Hi again,
It is showing this image, when I try to log in. I use my username Jonathanbm.
Med venlig hilsen / best regards
Jonathan Bruun MeyerAttachments:
You must be logged in to view attached files.-
July 30, 2026 at 2:16 pm #196582
Thanks for the info. Please email support@eventideaudio.com so we can help you further there since we’ll need further details about your account.
