Import of Pitchfactory presets to H90
Home › Forums › Products › Stompboxes › Import of Pitchfactory presets to H90
Viewing 3 reply threads
    • #168346
      lhesse
        How can I import my pitchfactory presets to H90?
        How can I im port .h9 presets to H 90?
      • #168381
        joecozzi
          Hi lhesse,
          In both cases, export your list out of H9 Control. Connect your PitchFactor or H9 pedal to H9 Control. It’s easiest if you are on a desktop. In H9 Control go to your Preset Lists and click on the name of the list. Up top on the right, click on Menu, then click “Export preset list.” Export it to your desktop. With your H90 connected to the same computer, open H90 Control. On the bottom left, under the Playlist, the third icon serves to “Import List.” When you click on it you have two options, one of which is to import an H9 List; click that and select the H9 list you exported out of H9 Control. It will create a new User List on H90 that features the algorithm on your list paired with the THRU utility because H9 lists only have one algorithm.
        • #168416
          lhesse
            Thanks for help.
            Is it possible to import single presets?
            • #168419
                Yes, in H90 Control click the 3 dot icon next to the Preset slot that you’d like to use, and select Import H9 “.tide” Preset or Import H9 “.H9z” depending on the file type you are trying to import.
            • #168446
              lhesse
                Thanks for thei Info. It works.
                Ludger
