independent recording for Sample 1 and Sample 2 H8000FW Preset 5224
Home Forums Products Rackmount independent recording for Sample 1 and Sample 2 H8000FW Preset 5224
    • #114537
      When I rec on Sample 1 – it records to Sample 2 at the same time. I want to sample different samples for Sample 1 d 2 – and play them both back simultaneous with different start points,  pitch and speed. Is this possible? In the INFO – it says that one can independently rec or playback with the audio control 1 and 3. What exactly does the 1 and 3 outputs refer to (hardware /internal routing?)
      Thx
    • #148072
        On looking at it, it appears that using the softkeys to record or play operates both samplers, so it records or plays all (4) channels.
        If you use the inputs 1 and 3 to perform an audio triggered record or play, you can drive the samplers independently.
        The inputs 1 and 3 refer to the inputs to the preset, after the routing. These will be DSPA_IN1 and DSPA_IN3.
        The INFO page correctly describes the operation.
        Note that the trigger EQ allows more control over the audio triggering, for example you could set it up so that a bass drum triggered the record or play.
