Home › Forums › Products › Stompboxes › INPUT Level on H9
March 28, 2016 at 12:46 pm #113370
If i follow a instructional video i can adjust only output level, holding a ACTIVE switch causes menu jumping to : active,preset name and output level…
No INPUT LEVEL menu point !
What i’m doing wrong?
Thanks in advance
March 28, 2016 at 3:24 pm #143015
Sorry – this got moved to the UTILS menu on system mode in the latest version. See the latest online UM for info.
The video you mention presumably refers to the older software.
March 28, 2016 at 4:08 pm #143017
Hi nickrose !
thank you for the raply,do you know what this can be ?
with both footswitches i’m entering the tuner menu but the LED ring around the big knob don’t light and the cent values are not displayed…
thanks
March 28, 2016 at 4:54 pm #143021sam68 wrote:
with both footswitches i'm entering the tuner menu but the LED ring around the big knob don't light and the cent values are not displayed…
This probably means that it is not seeing any signal. Check your connections, and be careful of PRE/POST.
March 28, 2016 at 4:56 pm #143022
I read now a new manual and i see that the art of displaying tuner values has changed but,anyway,i have no lightning ring around and nothing happens when i play the string,strange..hm
