Is it possible to step through H9 parameters in the opposite direction (XYZ)?
Home › Forums › Products › Stompboxes › Is it possible to step through H9 parameters in the opposite direction (XYZ)?
    • #116483
      llest
        Hi!
        Is it possible to somehow step through H9 parameters in the opposite direction in the XYZ expert-mode? For example, I want to play around with the delay’s A and B feedback. Currently, if I want to adjust the A-feedback after adjusting the B-feedback, I have to step through all the other parameters to arrive at the A feedback.
        Lauri
      • #157797
        joecozzi
          No, there is no way to step back. Only solution is to assign one parameter to X & the other Y for easier access.
        • #157798
          llest
            Thanks for your reply! Would be good if it was possible to step through the parameters both directions. I avoid laptops and mobile devices in my setup.
