Home › Forums › Products › Stompboxes › Line 6 Helix to H9 Max MIDI issue
February 17, 2017 at 11:41 pm #114017
Hey all,
Glad to finally have an H9 on my pedal board. I have connected it to the Line 6 Helix via the FX Loop 1 and also connected Helix MIDI out to the H9 MIDI in. I am getting very strange behavior when the MIDI cable is connected. When I disconnect it, the behavior stops.
When the MIDI is connected, the H9 output volume is incredibly low, but the input volume is good. I have to set the Helix FX Loop Input and Output to +6Db and set the patch on the H9 output level to +20dB. It is still very quiet.
As soon as I disconnect the MIDI cable from the Helix the behavior completely stops and the output level on the H9 is right where it should be. I have to set the FX loop input and output levels back to 0 and set the H9 output level back to 0 otherwise to quote Huey Lewis…”It’s just too darn loud”.
Any ideas what the heck is happening?
Thanks for the input!
Michael
February 17, 2017 at 11:43 pm #145771
Unless you have some unknown to science ground loop, I would have to say it depends on what MIDI messages are being sent to the H9, which are beyond my knowledge or control. Sorry.
February 18, 2017 at 2:58 am #145773
My bad, I was sending bank change with program change. Once I switched to a new MIDI channel and fixed that everything started working correctly.
February 19, 2017 at 10:00 pm #145785
Man…I was having the same issue. Thanks for having the same pain at the same time!
