Linking tap tempo settings on two Eventide units via midi?
Home › Forums › Products › Stompboxes › Linking tap tempo settings on two Eventide units via midi?
    • #112242
      sstacey
        Is it possible to connect an H9 and a Space pedal via midi so that when you stomp the tap tempo on one it sets the same tap tempo on the other?
        If yes, can it be set up so that tapping tempo on either matches the tempo on the other or is it a one way street?
        I'd like to be able
        To tap tempo on either unit and
        Have the other unit sync to it.
      • #127345
        achaput
          Yes it is possible to connect an  H9 and Space via MIDI and sync Tempo from one to the other. The easiest way to do this would be to turn on MIDI Clock Out on the master pedal and turn on  MIDI Clock In on the slave pedal.
          Setting them up as a two way street would not work. You can only have one be the MIDI clock source.
