Looper follows Midi Clock, but doesn’t respond to midi Play/Stop
Home Forums Products Stompboxes Looper follows Midi Clock, but doesn’t respond to midi Play/Stop
Viewing 3 reply threads
    • #166913
      frankie138
        When synced to midi clock the H90 will follow the tempo, but doesn’t play or stop with midi play stop messages like the H9 does.
        Is there a setting I may be missing, or does the H90 looper behave differently with regard to midi play/stop messages than the H9?
        Thank you.
      • #166914
          The Looper should be responding to MIDI Start/Stop. Can you be more specific with your setup and what device you are using to send the MIDI Start/Stop messages to the H90?
        • #166916
          frankie138
            Thanks for the reply!
            My mistake, I got this working.
            I thought that midi clock receive on the H90 was on as the Clock Source was set to Midi Din, but I neglected to also set the Tempo Source to Midi Clock.
            Once I change that setting Start/Stop work as expected.
          • #166918
              Glad to hear you got it working!
