Manual recombination of a “Structural Effect”
Home › Forums › Products › Plug-Ins › Manual recombination of a “Structural Effect”
    • #114393
      cauldron
        I was impressed by the potential of Fission and more generally of the method called “Structural Effects”. For example, I can do things I can not do with Sonnox Envolution for the simple fact that Fission allows me to act at a structural level maximizing the effectiveness of the treatment.
        It would be interesting to know if the latency is constant and how much is. I think different ways of allowing for external processing of the Transients/Tonal streams and I hope to implement something that allows this.
        I consider Fission as a powerful re-synthesis real-time method for sounds that have a substantial Transient and Tonal component. I am reminded of the structural power of IRCAM AudioSculpt but with the effectiveness and power of a low latency plugin.
      • #147329
        tlongabaugh
          Glad you dig it! Fission has roughly 50ms of latency.
          We are strongly considering a version that would allow for external processing of the two streams.
        • #147353
          cauldron
            Thanks for the updates. In the meantime, can I use two instances of the Fission plugin to process the same audio (Transients on the one hand and the other Tonal) and reassembling it manually? Would I have the same recomposition that should make Fission inside without creating artifacts?
            • #147355
              tlongabaugh
                Yes, that would work, providing the STRUCTURAL SPLIT sections have the same settings. With no effects on, the Transient and Tonal streams are complementary.
