Home › Forums › Products › Stompboxes › MIDI CC number
- This topic has 4 replies, 3 voices, and was last updated 3 years, 9 months ago by
peaceonu.
December 26, 2022 at 2:49 am #167959
Merry Christmas and Happy New Year.
I would like to know the CC number of presets in User 1 group to call with my midi foot switch
Thanks a lot
December 26, 2022 at 8:05 am #167962
Hello peaceonu,
Merry Christmas to you as well. If what you are asking about is how to recall Programs using MIDI, then the Programs on the Playlist can be recalled by sending Program Changes according to the number of the Program you want to recall.
PC1 = Program 1
PC2 = Program 2
PC3 = Program 3
etc.If what you are asking for is a list of assignable CC numbers, you can find that in the Systems settings under the MIDI category. Under “MIDI – Global Ctl” it’s possible to assign CC#s to various functions that control the H90.
If you wish to assign CC# to a specific parameter of a Program, this can be done by pressing the Parameters button. 6.4.1 of the user manual explains how to map CC#s across the entire Program.
January 2, 2023 at 1:17 am #168106
Thanks a lot! it’s a really big help
December 28, 2022 at 12:23 pm #168024
Just wanted to add… All MIDI devices should be assigned a unique CH number, unless your intention is to set all devices to OMNI mode.
To best specify the device you want to command via MIDI, it’s best to map each to a CH numb.
So…
Set MIDI from control/Pedal to transmit on CH 2… Set H90 to receive on CH2.
PC = Select Program within a UserBank (You’ve got to pre-select the User Bank right now).
CC – Continuous Control (Gain, FX Levels, Times, etc.) Set on each control in a Preset/Algorithm Use to OUTER RING (in Control SW) on EACH CONTROL to set the MiDI CC value RANGE. So you can set a MIN or MAX value using the outer ring and just send CC value of 0 or 127. If you set the OUTER RING to FULL Min/Max… you can increment or decrement any control to accurate value… with MID range being CC value 64.
Unfortunately, I’m still waiting for the method to change UserBanks via MIDI control.
Best!
January 2, 2023 at 1:18 am #168107
Thank you so much for your help
Happy new year
