MIDI Functions such as [RCV.CTL] and H9 Control App (for OSX)
Home › Forums › Products › Stompboxes › MIDI Functions such as [RCV.CTL] and H9 Control App (for OSX)
    • #114604
      cljfford
        If there a way to access MIDI Functions in the iOS or OSX H9 Control apps, I can’t find it. Is this only accesssible through the H9 pedal’s System Mode menu?
      • #148417
        gkellum
          cljfford wrote:
          If there a way to access MIDI Functions in the iOS or OSX H9 Control apps, I can't find it. Is this only accesssible through the H9 pedal's System Mode menu?
          Most but not quite all of the MIDI functions are in the apps.  If you click the Pedal Settings button in the bottom menubar, you'll find them under MIDI Settings.
          • #148431
            cljfford
              gkellum wrote:
              Most but not quite all of the MIDI functions are in the apps.  If you click the Pedal Settings button in the bottom menubar, you’ll find them under MIDI Settings.
              Thanks!  Once I entered my MIDI assignments into the H9 Control app, under Pedal Settingsl/ MIDI Settings/ Assign MIDI CC Messages to pedal functions, they showed up on the pedal in the System Mode [RCV.CTL], too.
