midi not going through modfactor correctly
Home › Forums › Products › Stompboxes › midi not going through modfactor correctly
    • #144969
      ROBLEISHMAN
        Use this and save yourself midi errors…
        http://www.midisolutions.com/prodqth.htm
      • #113843
        st.bede
          My midi chain is this Keith McMillian Soft Step 2 >  H9(core) > H9(max) > Modfactor > Source Audio Multiwave Distortion (this has to be the last since there is no midi Thru or out). I have midi+clock enable until the modfactor. The modfactor has midi Thru enabled. My expression pedal works perfectly from Soft Step out of both H9s but gets jumpy and laggy after the Modfactor. (The CCs into modfactor work perfectly). I also have the most recent update for the Modfactor.
        • #144977
            The H9's have better MIDI THRU performance than the Modfactor, so this may be the cause of your problem. As the man suggests, some kind of MIDI merge box would be a possible fix.
