midi remote help
Home › Forums › Products › Vsig and Preset Development › midi remote help
Viewing 3 reply threads
    • #105931
      I can't figure out why everytime I edit a preset in vsigfile the remote midi controler function gets lost. I want to assign an external midi controler to the preset parameteres but for some reason the function (hold select) on a parameter doesn't appear. Is there something I need to do after editing my presets?
    • #118044
       Hi
      unfortunately it's not clear what you mean.
      Please provide the folliwng for us, to try to replicate your issue:
      -Eventide unit
      -OS version
      -VSIGFILE version
      -a step by step description of what you do and what you expect the software to do for you.
      Thanks
      best
      I
    • #118047
      the problem I'm having refers to the midi capture function that allows you to assign a midi controller to a button. (Holding select on a parameter button>then midi remote window appears) I then enter a full controller value to set the remote but when i click "done" i get a error with a loud constant squeek noise. This only happens after editing a preset in vsigfile otherwise it works fine. I guess what im trying to figure out is what im doing wrong while editing.  Is it something to do with the function under tools called convert N_EXTCON to remoter? Im lost..
    • #129164
       This looks like an old bug.
      Again…which Eventide unit? Which OS? Which VSIG version?
      thanks!
      I
