Home › Forums › Products › Stompboxes › Midi Tap Tempo (Musicomlab EFX MkIII + Boss FS-5U)
March 23, 2012 at 1:13 am #108544
Hi everybody,
First of all I apologize if this question has already been answered. I browsed through this forum a bit but I could not find my exact problem.
I am using a Musicomlab EFX MkIII as the audio controller for my pedalboard. I would like to connect my Boss FS-5U to the XPDL jack on the Musicomlab, and then send a tap tempo to the Timefactor via MIDI.
I was thinking that I could assign a transmit channel on the Musicomlab and then have the Timefactor "listen" to the same channel for the tap function, but for some reason I haven't had any luck.
Any thoughts? Thanks!
April 12, 2012 at 5:46 pm #123310
Still no luck with this. In the EFX I can program the MIDI channel and controller number. I am using the same channel on the EFX and for the tap function on the TF. What controller number should I be using?
April 13, 2012 at 7:11 am #123312
Connect the FS-5U to the Xpdl-input. (I have my polarityswitch to the right, but I don´t know if it matters.)
EFX MkIII:
Enter Editmode (hold Mode-switch until it reads PC.1)
Press PS-1-switch until it reads ESW (it almost looks like ESu with a line over the u).
Press PS-3-switch and change the controllernumber to (in my example) 12.
Press Mode-switch again to step out of editmode.
Eventide:
Enter System-mode
MIDI
RCV CTL
Change the left field from BYP to TAP
Push the right footswitch (choosing the right field) and turn the decoder to example C12. I personally choose this because often the CC-numbers up to 11 are standard for certain parameters.
Just check that the two units speak with eachother on the same channel…
Gerangiro
