MIDIclock to H8000fw
Home Forums Products Rackmount MIDIclock to H8000fw
    • #108431
      MicrokevH8000
        I did a search and found someone with the same problem, but didn't see the solution, so please forgive me if this is a repeat. I'm assuming my problem is human error, so hopefully someone can point out what I missed. (it's 11pm in Germany right now, so my brain isn't all it could be.)
        I've got MIDI enabled in SETUP>MIDI. I've set MIDICLOCK as the source in SETUP>TEMPO, and I have a MIDI cable running into the IN port on the H8000fw. But when I send MIDI from my DAW, the tempo field doesn't change.
        The cable is coming from the THRU port on a synth that is receiving MIDI from my DAW. The synth gives no problems, so I'm assuming the H8000 is receiving the same signal.
        Have at me, guys. What am I too stupid to see here?Smile
      • #123146
        MFPhouse
          MidiClock works fine here.
          I am not shure if your Synth send the MidiClock through the Midi Thru.
          Be shure that your DAW send the MidiClock in the wright way .
          e.g Logic has special Rounding about this Parameter.
          Good Luck
