Mixed algorithms
Home › Forums › Products › Stompboxes › Mixed algorithms
    • #115392
      bansta
        The most often used mixed algorithms are DELAY + REVERB. So it would be nice to have more of those combinations as an algorythm. For example:
        TAPE DELAY + PLATE REVERB
        VINTAGE DELAY + SPRING REVERB
        DIGITAL DELAY + ROOM REVERB
        and so on.
      • #152180
        llemtt
          Also combinations of modulation + delay/reverb:
          FLANGER + DELAY
          CHORUS + DELAY
          FLANGER + REVERB
          take old Lexicon mpx100-500 series as a reference for “dual” effects, they’ll cover almost all everyone needs!
        • #152183
          bohan
            Have you guys tried SpaceTime, Mod Delay, and ModEchoVerb algoriothms? They can do some of the combinations you guys mentioned.
            • #152205
              bansta
                I have two H9. One device is being used for delays and reverberation, another one for modulation and special effects.
                Yes, I’m using SpaceTime a lot but this algo has to few tweaking possibilities. I would rather prefer to have delay + reverb only (without modulation) but with all controls activated.
              • #152207
                llemtt
                  Yes, already tried SpaceTime and ModEchoVerb but they offer too few parameters to control each (sub)effect to be useful to me:
                  if for instance I want a tzf into a pingpong delay a FLANGER/PINGPONG with 3-4 parameters to control the flanger and the remaining parameters dedicated to the delay could be ok.
                  A “simpler” dual-effect algo but with more control would be better than three-effect ModEchoVerb (too much “reverb” based). I love Spring which actually is TREMOLO/REVERB.
                  Consider then that you can easily build a lot of dual-effect out of your existing algos and SELL each as a different one…
                  You mentioned also ModDelay but it’s not clear to me how to use it as a dual-effect?
                  thanks
                • #152309
                  apalazzolo
                    thanks
                    mod delay: i think he is referring to the second post in this thread.
                    in mod delay, the top row of controls are for the dual delay.   the bottom row is for a modulated effect (chorus or flange).
