Mixing Link FX Loop Setup
Home Forums Products Stompboxes Mixing Link FX Loop Setup
    • #195954
      djg5000
        I make spacey experimental music with my guitar mainly using multiple guitar pedals (H90, Whammy, looper etc) and I got the Mixing Link to add my heavily effected voice from time to time within a long set to break up the guitar-centric sounds. Is there a way to setup the ML so I can still have the guitar as my primary sound source but peppering the vocals from time to time? Not looking to do both just one or the other because.. adding ML to the FX loop, drops the guitar signal about 20% …
        My original thought was that ML main footswitch could toggle between the guitar and voice.. Is there a way to setup ML so it can switch between guitar and mic? Also is there a way to adjust the volume of the two signals? My phantom powered mic is quite a bit louder than the guitar. Any solutions? Trying hard to avoid adding more things to the signal chain thus adding noise and losing signal
      • #195960
          I would suggest trying something like the setup described here: https://cdn.eventideaudio.com/manuals/h90/1.12.5/content/setup/mixinglink.html
          That would allow you to connect the guitar directly to the H90 for 1 path, and the microphone for a separate path.
          Let me know if you have any questions.
