Mixing link – why line level
Home Forums Products Stompboxes Mixing link – why line level
Viewing 3 reply threads
    • #113782
      Hey eventide!
      i’m a trumpet player and i’m working with guitar effects.
      I recently stumbled upon your mixing link, which seems like a good match for my setup..
      But, if i read correctly the ‘tofx’ – phonejack is using line level and most (if not all?) guitar pedals
      are working with instrument level. so, i’m confused why the mixing link isnt using instrument level for this output..
      could you shed some light on this?
      thanks in advance,
      tom
    • #144740
      JWaltz
        Hi Tom,
        MXLNK supports unbalanced pedal level and balance line level depending on the cable you use.
        What is cool about MXLNK  is that the FX loop will work gtr pedals and balance line level input.
        The User Guide list max level before clipping, but based on the gain knob setting and the interface cable you can have a good pedal level
        with some headroom leftover. This level is indicated by the signal present/soft-clip LEDs which monitor the GAIN control.
        thanks
        joe waltz
        eventide
        • #145487
          javiceres
            jwaltz wrote:
            Hi Tom,
            thanks
            joe waltz
            eventide
            That’s a really clever aproach… and triggers my interest: if I plug a guitar to the MLink and use the line level send to a stereo fx, say a digital reverb/FX rack unit (set to kill dry), how should I patch the stereo return into the MLink? Perhaps using the Aux Input? Or will there a level and impedance mismatch issue? And then, is the Headphones Out the only way to output the original dry sound + the stereo fx in, well, stereo? Is the stereo Headphone out suitable for the input of two guitar amps? An stereo FX return (line or pedal level/impedance) and Stereo Amp Out, is out of the capabilities of this unit? Because if it can be done, this would be my ultimate Swiss Army knife of preamp/mixer… Best regards. Javier
            Hi Javier
            yes, the AUX IN allows stereo input to be passed to HeadPhone output for a stereo pass-thru that  is mixed in with the other mono inputs.
            The main issue with this though is the headphone output does not have the headroom the other outputs have so the level will drop
            below unity gain. The headphone out will work for guitar amp inputs, because you have plenty of make up gain on most amp inputs.
            Yes, a full-blown high headroom stereo return and hi level stereo out are part of the features we would include on MXLNK MKII update!
            thanks for you interest
            joe waltz
            eventide
          • #147121
            joe waltz
            eventide
            Hi Joe,
            do you know a release date?
            Best regards, Andreas
        • #145578
          javiceres
            If anyone can help I’d be very thankful 🙂
            Hi Javier, see reply above
            joe waltz
            eventide
          • #145650
            javiceres
              Thanks !!
              I somewhat missed it…
