Modfactor Hanging
Home › Forums › Products › Stompboxes › Modfactor Hanging
    • #110953
      Modfactor still works, but the bank switches will begin to freeze…can't change banks at all. Tap tempo is NOT engaged. I reverted to prior version, thought it helped, then same thing started again. Have tried to reset to factor (keeping my presets)…no help. Is this hopeless? Unfortunately i just bought it used a month or more ago. Worked fine until the past week.
    • #124517
        It could be a bad switch, or a bad internal connection. You could have a handy friend open it up and look at it, or support@eventide.com
      • #124532
        No…this was clearly software related…more than one switch was affected and was intermittent, and acted more like a software snag. I reverted to the previous firmware and then re-loaded the latest firmware update, then did a factory reset. So far it has not recurred. Was very frustrating at the time. Keeping my fingers crossed….
