ModFactor Preset not active via Midi
Home › Forums › Products › Stompboxes › ModFactor Preset not active via Midi
Viewing 4 reply threads
    • #111501
      Hi There,
      I have ModFactor and TimeFactor pedals. I switch them both with a Liquid Foot Jr midi controller. Only simple PC messages to both for switching between presets. The TimeFactor works fine, but the ModFactor only switches to the correct preset, but it's not active.
      Any help woulkd be appreciated.
      Thanks,
      Gergely
    • #125636
        Does this apply to all presets ? If a preset is saved when not active it will load inactive from MIDI.
      • #125638
        Normal
        0
        21
        false
        false
        false
        HU
        X-NONE
        X-NONE
        Hi nickrose,
        Thanks for the quick answer. Meanwhile it turned out that it
        was some kinda software bug, ’cause I've "downgraded" the software to
        an earlier version, and everything is working just fine now.
        But your suggestion was some new information to me, thanks! 🙂
      • #136384
          But, note, earlier versions don't have this capability. Not sure where it came in.
        • #161371
          Paulsaf1
            I just updated to firmware 5 and have this problem with bank preset 1:1….can’t switch to it in active mode. Others do work. I resaved the preset by pressing the encoder button while in active mode on, still doesn’t work. Help?
            thank you
