Modfactor – Tremelo setting for Greenday
Home › Forums › Products › Stompboxes › Modfactor – Tremelo setting for Greenday
Viewing 4 reply threads
    • #111021
      msurry
        has anyone got close to the Greenday tremelo setting on Boulevard of Broken Dreams?  I;ve tried but still really feeling my way around with all the knobs and possibilities….
        Anyone got near it?
        Thanks
        Mike
      • #124651
        achaput
          Try these settings-
          Intensity 99
          Type "BIas"
          Depth 99
          Speed 1/8
          Shape "Square"
          Xnob 0
          DMod 75
          Smod 1
          Mod Rate 0.500
          Mod Source "Ramp"
          (Tempo ON)
        • #124653
          msurry
            Thanks will give this a go.
            Is this the best place for sharing presets? I had a look but couldn;t find that many that decribe cleary the tone they are tryng to create (I have a Timefactor too and am struggling a bit with the same thing).
            FOr delay, I am after a really basic delay to add a bit of depth – when I try most of the delay settings they sound too 'modulated/chorusey' for my taste if you know what I mean….
            Thx.
          • #124662
              Rumor has it that Green Day used an AdrenaLinn – Preset 140 – Tremolo Sequence 11.  I'm not so sure that preset reflects the settings that I hear.  I came much closer with the PitchFactor, preceded by a distorted Bogner Uberschall model.
              There are a few ways to go about it with the PF.  Here's one that takes advantage of the strings' natural decay. [ Fm / Fm | A / A | E / E | B / B ] :
              GreenDayBoBD
              Mix = WET:100
              Pitch Mix = A10+B10
              Pitch A = ArpA: OFF
              Pitch B = ArpB: OFF
              Delay A = GrvA: A07
              Delay B = GrvB: B07
              (encoder) = PEGGIATR / TMP ON (~ 85 BPM)
              Depth / Key = ATK:  5-10
              Speed / Scale = LN: 1/64
              Xnob = FXA: OFF
              Ynob = FXB: OFF
            • #135505
                To be fair, the ADR III preset 140 actually does pull off the Green Day riff – in its initialized state.  That's what I get for tweaking or replacing all of the factory presets!
                It has an somewhat slow attack/decay envelope on each sequence step [3-3 out of a possible 9-9].  So the PitchFactor preset above can emulate this softened attack with a Speed / Scale setting as low as ATK: -5.
