Modfactor wet/dry mix
Home › Forums › Products › Stompboxes › Modfactor wet/dry mix
Viewing 3 reply threads
    • #108542
      I just picked up a modfactor. Is there really no knob for setting wet/dry mix? And controlling stereo spread? no?
    • #123264
      achaput
        In the newest software update we've added a wet/dry control for the Rotary effect. For the other effects, the Intensity control lets you alter the perceived amount of effect although it is not always a 'wet/dry' control in the classic sense. This is because effects like Flangers and Phasers completely replace the dry signal to achieve their sound.
        -Alan
      • #123265
        Can you please explain what is meant by the term "wet/dry" control. I use the Rotary Effect on my Modfactor and if there is some kind of additional enhancement I would like to know what it does.
        Thanks
      • #134362
        achaput
          A wet/dry control lets you dial in any amount of the original, dry sound with the effected sound. It lets you mix the two sounds together. In the Rotary this allows you to get a more subtle rotary effect.
