Home › Forums › Products › Stompboxes › mono or stereo per preset
March 24, 2018 at 7:09 pm #114668
Hey everyone,
I was wondering if it’s possible to set the pedal in mono or stereo for each preset.
For example, I’d like to use a reverb preset as stereo in a song, but a delay preset in mono in another song.
Can I set it up for each preset? if so how?
April 4, 2018 at 7:09 am #148878
anyone able to help me with this?
April 4, 2018 at 11:42 am #148880
I don't understand what exactly it is you're trying to do and why you'd want to do this. For example do you have two channels going to two amps and you want to switch from sterero to mono to effectively turn off on amp?
In any case the H9 supports several different routing modes:
https://www.eventideaudio.com/support/downloads/setting-prepost-routing-options-h9
April 4, 2018 at 1:24 pm #148882
Hey thanks for replying and sorry if my post was confusing.
Basically I’m using one of the delays in the h9 with two delays each at a different tempo.
I play with a stereo rig (2 amps), and my problem is that delay A plays only on the right amp and delay B only form the left amp.
Would it be possible to have both delays playing on both of them?
The same it’s even more prominent when I use Ultra Tap (I think I’m using the “stutter” preset).
Would it be possible to change this here as well?
At the same time in another song I use an effect that does kinda the same bouncing between the two, but in that case I like the way it is, that’s why I was asking if it can be set differently for each effect.
Please let me know if you need more info
