Naming a preset in V3 Timefactor
Home › Forums › Products › Stompboxes › Naming a preset in V3 Timefactor
    • #108030
      I'm sure this is an obvious one but for some reason it evades me in the user guides
      I can save a preset now but how do I change the name on it?
      Thanks for in advance for answering a newbie question….
    • #122493
      achaput
        Preset Naming
        Eventide Stompboxes now give you the ability to name your Presets. When you
        load a new Preset in Bank Mode, the entire Preset name will scroll once.
        Then the Bank/Preset number will be displayed, followed by the first
        4-6 letters of the Preset Name.
        To Edit the Preset Name:
        -After entering Save Mode, press the Right Footswitch and the first
        character of the Preset Name will flash. Turning the Encoder will change
        this character. The available character set is 'A-Z','a-z', '0-9'.
        The Left and Right Footswitch LEDs will be flashing green, to show that
        TimeFactor is in Save Mode and that these switches can be used to
        navigate between edit fields.
        – Use the Left and Right Footswitches to traverse the display,
        selecting a field to be edited by the Encoder. (The active field for
        editing is always flashing.) Repeated pressing of the Right or Left
        Footswitch will traverse through the name field one character at a time,
        flashing the selected character.
        – The cursor will “wrap around
        the display.” Pressing the Left Footswitch will move the edit field to
        the left by one character at a time until it gets to the first
        character. Pressing the Left Footswitch from here will jump to the last
        character of the Preset Name.
        – A phantom space is always present at the end of the name to allow
        characters to be added past the end. The phantom space cannot be deleted
        but will be removed on exit.
        -When you are finished naming, either press and hold the Encoder
        Button to save the Preset, or press the Middle Footswitch to exit
        without saving.
        Special Footswitch Presses/Shortcuts for Naming Presets:
        1. Press and hold Left Footswitch to DELETE the current flashing character.
        2. Press and hold Right Footswitch to INSERT a character before the current flashing character.
      • #124697
        Is it possible to turn off the name feature? I find the scrolling slows things down programing a ground control pro if you don't know what bank your on. Also I really like how my space is 1 preset per bank. Instead of 1:1 1:2 2:2 3:1 ect…… Do you see this being an interface option on later updates of timefactor and mod factor.
