New Blackhole pedal stops “working” after an hour?
Home › Forums › Products › Stompboxes › New Blackhole pedal stops “working” after an hour?
    • #157369
      tsternfeld
        Hi, some questions to get you moving:
        Have you updated your pedal?  There is new software available that fixes a bug we found after we shipped the first batch of Blackholes where something similar could happen on some units.  You'll need to plug in the USB to a computer and use Eventide Device Manager to update to the newest version  (1.0.1[0]).
        Are you using the included power supply?  This could also happen with a power supply that isn't providing enough current to properly feed your Blackhole.
      • #116392
        I just bought a new Blackhole pedal (February 20210), and after being powered on for a while (an hour or so), the pedal acts like it’s in bypass. I hear my input but with no effect applied. Power-cycling resolves the issue, but the pedal continues to “turn off” after a while. I haven’t changed any of the presets or done anything else but use the pedal at its default settings.
      • #159688
        pytheus
          Blackhole tone question:
          Hi all,
          Thank you in advance!
          Does anyone know if the Blackhole can this sound Trey is getting from the Space?
          start 21:25
        • #157442
          Thanks for your reply! No, I haven’t updated the firmware yet. I just bought it (March 2021) so I assumed it was recent stock. I was using a new Trutone 1Spot 9V PSU and also tried a premium Dunlop 9V power supply (i.e., larger PSU with thicker cables) with the same results. Will try the firmware upgrade next and report back. Thanks!
