No External Option on the Eclipse
Home Forums Products Rackmount No External Option on the Eclipse
Viewing 3 reply threads
    • #193190
      papertree
        Hi all,
        I am trying to set up a midi controller to use with my school’s Eclipse, but I can’t find the “External” option under Setup.
        This machine is running on V1.020, and I can’t update it — since it is school’s property.
        Is there any luck for me?
        Thanks! =)
      • #193199
        italoop
          You should REALLY REALLY REALLY update that Eclipse to V4. It just doesn’t make sense to be on that very early OS release.
          Talk to the school folks and make them understand the much better value the latest OS adds to the machine in terms of funcionality, algorithms and presets and reliability.
          • #193201
            papertree
              I will definitely do that, although that machine doesn’t get much use…
              For now, I would really love to know if the fact that the External option is missing is because of the firmware or because I am missing something…
          • #193226
            italoop
              The User Manual V1.0 shows EXTERNALs. They are 8. Latest OS has 16!
              They are in the MODULATION BLOCK, under PARAMETER page 2 <EDIT MOD>.
              You should refer to the user manual.
              • #193228
                papertree
                  I could not for the life of me find the manual for V1.0. Would you mind sharing?
                  Thanks! I will try to follow your steps.
              • #193229
                italoop
                  Uploaded here.
