Older TF Not “Spilling” Properly
Home › Forums › Products › Stompboxes › Older TF Not “Spilling” Properly
Viewing 3 reply threads
    • #107308
      wes
        I have an older TF, which has always been a little less sturdy than the newer eventide pedals I've bought. Since the newest update, when I change between presets, it makes loud oscillation sounds as if all the knobs go to 100% for a second before the change. It only happens when switching between certain algorithms, but when it happens, it's VERY obnoxious and distracting.
        I tried turning Spill mode off, but then I could hear the delay times changing between presets, which is also not very useful.
        Like I mentioned, it's not the most rugged pedal and it might just be broken, but if there's any way to fix it please let me know.
        Thanks for your help.
      • #120828
          Apart from the odd component changes, most notably switches, there really aren't any differences between newer and older models, so it's hard to know what to suggest..
          As a first step, I would advise a total restore to factory settings as described in the User Manual. This will lose any saved presets.
        • #120833
          caveman
            I had some freaky-deaky problems with an older timefactor right after the latest software upgrade..  Resetting made no difference.  Out of exasperation, I reloaded the software.  The problem then disappeared for me.  It might be worth a try …..
          • #132149
            i have this same issue when going from mod-delay to vintage delay and occasionally with mod-delay to tape…
