Orville and Eventide Routing Utility 2.8 problem
Home › Forums › Products › Rackmount › Orville and Eventide Routing Utility 2.8 problem
Viewing 6 reply threads
    • #112937
      I’ve been trying to use the routing 2.8 (H8000A) with Orville but it keeps refusing, saying: This program can not be used with Orville.
    • #141025
        I'm afraid it probably means what it says – this version only supports the H8000 family.
      • #141029
        The manual states  that Orville is supported by previous versions of this program. Where can I obtain it? Thanks
      • #141030
          I've attached an earlier version (WIndows only). You should rename it from .txt to .exe and run it.
          Note that there is ZERO support for this (it's a 13 year old program), so please use it at your own risk.
        • #141031
          This version works like a charm. Thank you so much for that, cheers! Ely
        • #141209
          Monib
            Can you post the Mac version as well? I can seem to find it.
          • #141210
              Sorry – there is no Mac version for Orville. This only appeared with the H8000 version.
