Os 5.8.5 or IOS 3.7.0 problem
Home Forums Products Stompboxes Os 5.8.5 or IOS 3.7.0 problem
Viewing 4 reply threads
    • #115709
      PBS
        A warning constantly appears on my IOS H9 Control. I have a Max and a Core. I can’t control the devices via Bluetooth. I have the latest Os and IOS install on all devices.
        Sometimes it works fine but most of the time it fails.
      • #153784
        BassBoogieMan
          I have the same configuration of Max ans Core with the same problem. Both devices will connect and the one or both will disconnect with the same error. Happens to both of my iPads and my phone. Pretty much the same problem with my MacBooks and Blue Tooth. It works fine with MIDI.
        • #153788
          bohan
            Hi Guys, we realized there is a Bluetooth connection issue due to iOS 13 changes the way how the Background Mode works. There will be a production release which solves this problem. But for now, you can join our beta and download the version that fixes this temporarily.
            Here is the version you can update (you need to install TestFlight on your iOS devices first): https://testflight.apple.com/join/rTMrrvEQ
          • #153793
            glenza
              Same issue here!
              Is this beta version will delete my users presets on iPad?
            • #153824
              tauk
                OK – My real concern is that after updating to the latest firmware, I get the message in the OP and now my expression pedal has stopped responding – seriously, I have shows this week and now the H9 isn’t working.
              • #153792
                glenza
                  Same issue here!
                  Is this beta version will delete my presets on iPad?
                • #153798
                  bohan
                    glenza wrote:
                    Same issue here! Is this beta version will delete my users presets on iPad?
                    No. But you can also back up (export) your user presets first before updating the H9 Control.
                  • #153825
                    bohan
                      tomattah wrote:
                      OK – My real concern is that after updating to the latest firmware, I get the message in the OP and now my expression pedal has stopped responding – seriously, I have shows this week and now the H9 isn't working.
                      Are you using this new beta version? https://testflight.apple.com/join/rTMrrvEQ
