Home › Forums › Products › Stompboxes › Output level assign to X,Y or Z buttons?
- This topic has 4 replies, 2 voices, and was last updated 3 years, 8 months ago by
snailspacejase.
April 7, 2022 at 1:26 pm #163089
Hi
I was wondering if it possible to assign the preset output level to one of the X,Y,Z buttons of the H9. They seem to be able to control all the other parameters apart from output level. Any ideas?
Cheers
April 7, 2022 at 1:33 pm #163090
Hi snailspacejase, this is not possible.
April 10, 2022 at 7:17 am #163126
Wow, I’m supprised. I don’t think I’ve ever owned a pedal that does not have an output level control. So let me get this straight, if I want to control the volume of a preset I’m going to have to open the app on my phone?
I don’t wish to sound negative. The H9 is a great tool and I’m very pleased with it.
April 10, 2022 at 9:11 am #163127
The original question was whether or not Output could be assigned to X, Y, Z. If you wish to set output level for a preset:
Press and hold the Left Footswitch – the Preset will now be Active. After holding for 2 seconds, the display will show [OUTLVL], and then a second later [0] (or the current value). Continue holding the Left Footswitch while turning the Knob to adjust output level from -12 dB [OUT-12] to +12 dB [OUT+12] in 1 dB increments. Release the Footswitch – the Preset will return to its previous Active or Bypassed state. The next time you do a Press and hold of the Left switch it will return to the last thing you adjusted.
Note: Preset output levels must be saved even if there are no other changes to the preset or the output level will revert to its previous setting the next time the Preset is loaded. In other words, if you want the adjusted output level to ‘stick’, you must re-save the Preset.
April 11, 2022 at 5:29 am #163128
Perfect. Thank you for taking the time to explain this, much aprieciated.
