Outputs line vs amp
Home Forums Products Stompboxes Outputs line vs amp
    • #108473
      bmwm3cs
        Been playing with Space pedal for about 2 weeks now. I am loving it, the more time I spend with it the better it gets.
        What does the amp/line selector do, adjust volume?
        I am asking because for certain algorithms the line level makes the preset sound more detailed. Others algorithms like hall sound better with the amp level.
        Is there anything I can do about this in a live situation without having to use two Space pedals.
        Thanks,
        Jason
      • #123179
          Strictly speaking, the purpose of the gain switches is to adjust the pedal to the input and output signals needed. But, if you have a low output guitar, you may prefer the gain boost you get by going in guitar and coming out line. Or not.
          If you want to achieve this in a live situation you can adjust the preset output level to boost the gain by 6 dB where desired – this is about the same as the output level switch. See UM p.16
        • #123184
          bmwm3cs
            Thank you for the help.
            Jason
