Pedal power vs power factor
Home › Forums › Products › Stompboxes › Pedal power vs power factor
Viewing 4 reply threads
    • #108116
      sjoplin
        Anyone using the voodoo labs pedal power AC which claims to power 4 factor pedals? Wondering how it compares to the Power Factor which does 3 factors but also has other 9VDC options.
        Curious if anyone is using the voodoo labs unit and has all 4 factor pedals.
        Thanks
        Sean
      • #122681
        DavidYates
          I just built my own 8-output, fully isolated, regulated custom supply for my pedal board. Has 'Factor power, Moog power, AC voltages for other pedals…
          It was a lot of work and in retrospect, not worth all the trouble compared to buying a couple supplies to fit my needs.
          Lots of choices out there, some much better than others, just no "one-size fits all" solution.
          David
        • #122682
          sjoplin
            Dave, thanks for the feedback. I thought about building one as well and you have confirmed that it's probably not worth the hassle. The factors have several solutions available, what I am struggling with is the voodoolab GCX audio switcher and GCX mixer. They are both 9VAC but have a weird 4 connector power supply cable coming off of a wall wart transformer. I'll drop their support team an email and see if they have any in house solutions for those pieces. The wall warts just don't integrate into a rack system well at all.
            Thanks
            Sean
          • #122683
            sjoplin
              Typo on my end as well, should have said the power pedal digital and not AC.
              Thanks
              Sean
            • #133835
              DavidYates
                Just make sure the isolation is really good. I was not too impressed with the solutions I saw back when I was working on it. I think things have improved since then.
                I didn't want to have a board full of expensive efx that hummed…
