Physion MKII latency issues on Mac
Home Forums Products Plug-Ins Physion MKII latency issues on Mac
    • #193336
      diegolum
        Hello, I am testing Physion MKII in Live on a Mac M2, and when this plugin is in a Live project, I immediately experience a significant latency delay with the instruments coming through the MOTU M6 sound card. Even if I turn off the plugin, this delay still occurs, but if I delete it, I immediately regain the good latency of my card. Is this normal behavior for this plugin? Is there a solution to this problem? It is very difficult for me to use under these conditions.
        Other plugins are working OK.
        Thanks in advance
        Diego
      • #193337
          Physion MKII introduces an amount of latency that is necessary for the tonal/transient split. DAWs have latency compensation functions that will delay the other tracks so there is the same amount of latency applied to all tracks.
          If you bypass the plug-in using the Ableton Live plug-in bypass button (also called the “Device Activator”), this will bypass the latency.
        • #193351
          diegolum
            Hi, thank you very much for your fast answer, so i’ll do that bypass when streaming external instruments.
            • #193359
                You’re welcome!
