Home › Forums › Products › Stompboxes › Pitch flex with expression pedal
- This topic has 5 replies, 3 voices, and was last updated 3 years, 2 months ago by
badmoki.
January 6, 2023 at 4:38 pm #168316
no matter what i set the “heel down” (or up) to with the H90 control it goes back to 0 when i move the pedal to heel position…Using a dunlop pedal with trs cable.
Likewise, no matter what i set them to they go up to P11 when toe is engaged with pedal.
Thanks,
Smith C
January 6, 2023 at 5:34 pm #168317
Hi badmoki,
When you say
are you referring to expression ranges of an algorithm on H9 Control? Which algorithm?
Have you calibrated your expression pedal?
January 8, 2023 at 11:12 am #168351
So like I said in the title of thread it’s the pitch flex alg— “flex harmony+3rd” preset…I haven’t tried other presets. but let me look into calibration..Thanks Joe!
January 8, 2023 at 11:19 am #168352
ok, so calibration made it so heel position on the pedal sets the 4 “heel and toe” params all the way counterclockwise on the H90 control app when pedal is set to heel and all the way clockwise when pedal is moved to toe…Is there a way I can set the “heel A” and “heel B” params to START at say unison or anything other than “off” and end with toe anywhere other than +2 oct?
Thanks,
Smith
January 8, 2023 at 1:40 pm #168362
Go back to where you programmed Heel & Toe A & B (for each of the four parameters). There is a 2nd page after the parameter – expression page. Turn the Select knob to access it. Set the START & END points with the Quick Knobs. Press Perform to confirm it.
January 8, 2023 at 1:42 pm #168363
oh wow, thanks Brock!
