Pitchfactor + Mission Engineering SP1
Home › Forums › Products › Stompboxes › Pitchfactor + Mission Engineering SP1
    • #109602
      I have a Pitchfactor connected to the Mission Engineering SP1 expression pedal.
      Something strange happens: When I'm in heel position it shows 0, but when I'm in toe position it also shows 0.
      Somewhere in the middle there is the 100 value.
      So actually it goes from 0 to 100 and back to 0.
      Has anyone had a similar problem?
      Thanks, Caspar
    • #124301
        Sounds like it is wired with both ends of the track connected together . You are probably using a mono cable when the pedal is wired for a stereo (TRS) cable.
