Pitchfactor power jack loose/sensitive – unit often resets or resets in a loop
Home Forums Products Stompboxes Pitchfactor power jack loose/sensitive – unit often resets or resets in a loop
Viewing 3 reply threads
    • #108662
      beedoola
        I've heard this happen to other folks. I have both a Timefactor and Pitchfactor the and TF's power jack is fine but the PF's is loose – sometimes the unit will reset, as if I unplugged the power, when I engage a preset or accidentally graze the power cable with my hand. Sometimes when it resets, it will keep resetting in a loop – on/off, on/off, etc. until I hold the power cable a certain way.
        I'm using a voodoo labs pedal power 2 plus to power both factor pedals.
      • #123354
          Probably needs resoldering. If it's out of warranty, find a handy friend, or return it to us or your dealer. Could also be physical damage to the connector, or a problem in the jack itself.
        • #125255
          andystates
            I just started having the same issue. I purchased it a year or two ago on ebay and was in perfect working order. Can eventide do the repair?
          • #136074
