PitchFactor Vibra Chorus – Stereo/Mono issue
Home Forums Products Stompboxes PitchFactor Vibra Chorus – Stereo/Mono issue
Viewing 3 reply threads
    • #109534
      lst
        Hi!
        I have a PF set up in stereo in my rig. Two inputs (from FX loop through an A/B box capable of selecting both inputs active OR either IN1 OR IN2 as active).
        Now. Using the preset Vibra Chorus I have a strange behaviour:
        – when both inputs to the PF are active. everything is fine.
        – when only IN1 is active I get sound to one (OUT1) amp only
        – when only  IN2 is active I get no sound at all. It´s all muted.
        Is this normal and just some stupid error on my side.
        The other presets are all fine (haven´t tested all of hen but Chorus for instance)
        Any help appreciated – Thanks!
      • #124232
          That preset has the Pitch Mix at A10 + B0.  You might want to change that to A10 + B10 to see if it makes a difference.  I have a feeling that your system settings under Bypass might be contributing, with KillDry set to Yes.  I have a stereo rig here, but it's a series routing to a rack mixer, while yours is in an FX loop.
        • #124233
          lst
            Thanks I will try this asap!!
            Br Lars
          • #124234
            lst
              The mix change did the trick – thanks!!!
