Home › Forums › Products › Stompboxes › Plugged in the wrong power to H9
- This topic has 4 replies, 4 voices, and was last updated 3 years, 11 months ago by
IronStomach.
April 11, 2022 at 8:21 pm #163130
Hi all, I’m probably 0verthinking things but I got a new power supply (Fender Engine Room) and the cables it comes with have the colors reversed from my previous one – I accidentally had center negative power plugged into the H9 a few times for less than a minute before I realized why it wasn’t turning on and checked everything. It’s working now, so I’m just wondering if it’s safe to keep using it? Would anything have been damaged or does the pedal have reverse polarity protection?
Thank you!
April 12, 2022 at 4:25 am #163131
I don’t have a definitive answer about reverse polarity protection with the H9 I’m afraid.
I have had issues with connectors though, reverse or otherwise, concerns g the future of the centre receptacle. Sadly a whole batch of cables that just didn’t work unless I physically offset the plug (which is a socket really). Sadly not all cables are created equal.
April 12, 2022 at 7:15 am #163132
Modern devices must have a protection circuit to provide damages in case of connecting with wrong polaraity.
Especially US and Europe devices a carefully build. Imagine a wrong polaraity causes a device getting hot an your house is burning down…
Their are special ICs designed for that. This ICs also care for a constant voltage level …
Reading your device with too high voltages is not possible because different voltage categories have different plugs which don’t fit.
Enjoy your device
April 12, 2022 at 8:20 am #163148
The H9 has reverse voltage protection on the power input, so it should be OK.
Always be careful …
April 12, 2022 at 10:30 am #163163
For sure, thanks all. I wont take it for granted!
