Possibility to morph between presets on Blackhole pedal?
Home › Forums › Products › Stompboxes › Possibility to morph between presets on Blackhole pedal?
    • #116108
      fabeck01
        I’m wondering whether it is possible to morph between presets on the Blackhole pedal using an expression pedal connected to the rear jack?
        The description says: “Map any combination of parameters to an Expression Pedal”. The manual says: “An Expression Pedal can be used to change any grouping of knob Parameters in one smooth gesture.”
        This is a feature the Meris Mercury 7 pedal offers which I was contemplating buying … until I just saw the new Blackhole pedal. 🙂
      • #155843
        bohan
          fabeck01 wrote:
          I'm wondering whether it is possible to morph between presets on the Blackhole pedal using an expression pedal connected to the rear jack?
          The description says: "Map any combination of parameters to an Expression Pedal". The manual says: "An Expression Pedal can be used to change any grouping of knob Parameters in one smooth gesture."
          Yes, you can use the expression pedals to morph between 2 sets of different parameters, which are like basically 2 presets
        • #155884
            If you really want 2-in-1 preset options, you can use an AUX switch.  A latching switch will snap to Toe or Heel ‘presets’ on alternate switch presses.  A momentary switch will, of course, keep the Toe programming for as long as you hold down the switch.  Heel / main preset on release.
            Keep the Global setting at EXP, or EXP+AUX.  Program your Heel & Toe extremes as you normally would (but with a switch, not a pedal).  Pseudo-HotSwitch functionality, found in many H9 algorithms.
            Now, the true morphing with an expression pedal “in one smooth gesture” … that’s where the real beauty lies here.  Simple MIX adjustments, or bending space & time.  And Lexicon Vortex-style, the cocked throw positions can be as interesting as either extreme.
