Home › Forums › Products › Stompboxes › problem updating h9 from 5.4.1 to 5.8.5
- This topic has 9 replies, 1 voice, and was last updated 4 months, 2 weeks ago by
laptoples.
February 15, 2020 at 1:55 am #115767
Problem updating H9 5.4.1 to 5.8.5 and i get a “bad” message on the unit. i’ve tried bluetooth from 2 different devices and usb straight to mac. I read that if the unit takes 10 seconds to power up there are alternative directions to install update. Can anybody help?
Could you try updating your H9 using the Direct Updater via USB? I's bundled with the H9 Control app. You can find it in H9 Control by clicking "Window" -> "Open Direct Updater" in the menu bar. Note that you would need to power on the H9 with HOTKNOB pressed to boot into the UPDATE mode to do the update.
February 17, 2020 at 7:45 pm #154098
tried to update with direct installer now h9 just reads “update” and does not function
February 17, 2020 at 9:49 pm #154100
i tried that as well. is there a direct file i can uplaod through direct uploader? very frustrating…
February 17, 2020 at 11:13 pm #154102
i installed the update several times with no success. The issue now is that the pedal will no longer connect to h9 control. It’s stuck with the screen reading “Update”, “ready”
I cycled power with hot switch button down and with hot buttom and right footswitch as well. What should i try next?
February 17, 2020 at 11:39 pm #154103
yes it was fine before the update
May 2, 2026 at 9:25 am #195289
Hi, I just updated my H9 but there was 5.4.1 and up to 5.9.1 that wasn’t downloaded yet.
Do I need to go update all the older ones or am I up to date with 5.9.1 Installed ?I only installed 5.9.1.
Thanks !!!
February 17, 2020 at 9:32 pm #154099pete100199 wrote:
tried to update with direct installer now h9 just reads "update" and does not function
So you updated your H9 to the lastest firmware in the Direct Updater? It's worth trying to reinstall the firmware again and reinitialize the unit (powering up with HOTKNOB and the right footswitch pressed and held)
Was your H9 fine before the update?
You don't need an update file. You can just select a version in the Direct Updater and click "Install Update".
February 18, 2020 at 5:14 pm #154106pete100199 wrote:
i installed the update several times with no success. The issue now is that the pedal will no longer connect to h9 control. It's stuck with the screen reading "Update", "ready"
If reinstalling firmware in the Direct Updater and initializing the unit doesn't work, email support@eventide.com
